I am finally getting around to messing with the Dahua turrets I bought and am wondering how most people adjust the settings for their cameras.
Are you supposed to make most of your adjustments/settings locally to the camera and then Blue Iris is used more as only a recording service? Or do you also adjust camera settings in Blue Iris?
Also, while I have you (and because I couldn't find how to adjust it in BI, which is what led me to ask the above question). Is there a way to know what focal length a varifocal is set to so that you could buy the corresponding fixed focal length camera? I have an IPC-T5442TM-AS 2.8mm and an IPC-T5442T-ZE VF. I am currently messing with the VF but have no clue what it is set to unless I am at either extreme.
