- Nov 8, 2016
- 4
- 1
Title. I know the Dahua PFA130-E mount comes with one of these black rubber plugs where the camera mounts flush to the base of this mount. I am wondering if anyone knows where I can buy more of them or somehow get 3D prints of it?
thanks!
McMaster-Carr, they're sure to have it. But it's gonna be a bulk of some sort, like a 25-Pack or something. Just type "rubber plugs" in their search field and myriad results will present. Click on any part number link for any type and "product detail" will show a 2D CAD drawing with all your dims.
The G-3/4 spec is a threaded hole, I know threaded plugs go in there, and I know there's a large rubber plug in some of the boxes, but I didn't know the plug that came with some of my Dahua boxes went in the 3/4" threaded hole.
Wow, I really like how they have 2D CAD drawings of everything. That helps so much, thank you for sharing the site.McMaster-Carr, they're sure to have it. But it's gonna be a bulk of some sort, like a 25-Pack or something. Just type "rubber plugs" in their search field and myriad results will present. Click on any part number link for any type and "product detail" will show a 2D CAD drawing with all your dims.
Yes, I would want a similar sized rubber plug of the one used that goes in the center of the faceplate of the mount. I think it fits well into the G3/4" holes on the side, but, I have to try it again to confirm (been a while). If it doesn't, then for sure I can get dimensions and definitely find something I can use from McMaster-Carr. I had so much trouble finding a good store for odd pieces like the rubber plugs available in many different sizes.+1 on McMaster-Carr as a source.
I believe OP is looking for the cable seal that goes in the center of the faceplate, not the side entries
Yes, they're an awesome supplier. And in many cases (ALL of my cases), the shipment arrives "next day" even though it's standard ground*. They have trucks continuously going to the airport all day long.I knew there was another common source besides Grainger and I could not think of the name![]()
