Q qbertopp n3wb Oct 30, 2014 25 0 Apr 23, 2018 #1 I need to downgrade when issues occur. Where can I find the older builds of BI4?
Tinman Known around here Nov 2, 2015 1,522 2,056 USA Apr 23, 2018 #2 qbertopp said: I need to downgrade when issues occur. Where can I find the older builds of BI4? Click to expand... Blue Iris Update Helper (BiUpdateHelper)
Q qbertopp n3wb Oct 30, 2014 25 0 Apr 23, 2018 #3 Tinman said: Blue Iris Update Helper (BiUpdateHelper) Click to expand... Those seems to only be the BI helper builds. What I need are the last few BI4 updates.
bp2008 Staff member IPCT+ Member Mar 10, 2014 13,220 15,115 USA Apr 23, 2018 #4 Here are a few, assuming you're running 64 bit. Dropbox - update64_4.6.9.2.exe Dropbox - update64_4.6.5.4.exe BiUpdateHelper will make automatic backups of all your update files (and registry settings!) so you will always have them on hand when needed.
Q qbertopp n3wb Oct 30, 2014 25 0 Apr 23, 2018 #5 bp2008 said: Here are a few, assuming you're running 64 bit. Dropbox - update64_4.6.9.2.exe Dropbox - update64_4.6.5.4.exe BiUpdateHelper will make automatic backups of all your update files (and registry settings!) so you will always have them on hand when needed. Click to expand... Thanks
