Brian Bain Young grasshopper Jul 27, 2015 49 5 Aug 18, 2015 #1 Is it expected that if I am recording in MP4 format that I will get "unable to connect" when viewing video through the BI client and the web? thanks! Brian
fenderman Staff member Mar 9, 2014 36,891 21,418 Aug 18, 2015 #2 Brian Bain said: Is it expected that if I am recording in MP4 format that I will get "unable to connect" when viewing video through the BI client and the web? thanks! Brian Click to expand... You need to install the k-lite codec pack here...http://blueirissoftware.com/third-party-software/ Keep in mind that blue iris dvr format is the most efficient and allows playback of the clip while its recording. Reactions: Brian Bain
Brian Bain Young grasshopper Jul 27, 2015 49 5 Aug 19, 2015 #3 fenderman said: You need to install the k-lite codec pack here...http://blueirissoftware.com/third-party-software/ Keep in mind that blue iris dvr format is the most efficient and allows playback of the clip while its recording. Click to expand... Awesome that worked! I guess maybe I should do bvr then convert for archival. thanks!
fenderman Staff member Mar 9, 2014 36,891 21,418 Aug 19, 2015 #4 You only need to convert if there's an event that you want to share.. Sent via Taptalk
Brian Bain Young grasshopper Jul 27, 2015 49 5 Aug 19, 2015 #5 fenderman said: You only need to convert if there's an event that you want to share.. Sent via Taptalk Click to expand... since I am recording on a server it's easier for me to play also since most of the time i'll be playing on a machine that doesn't have BI.
fenderman Staff member Mar 9, 2014 36,891 21,418 Aug 19, 2015 #6 In that case I would simply record to mp4 Sent via Taptalk
