A beginner question. Am getting four IPC-HDW5231R-ZE from Andy for indoor mounting on walls (drywall surface) and one on top of a partial-height wall (plywood surface). Cabling will run over the surface of the wall. Have read the cliff notes, but just wanted to double-check to ensure a complete order.
My impression is that I can attach the cameras directly to the walls without a special mounting bracket.
Dense persons guide to the Dahua IPC-HDW5231R-Z
Are the brackets mostly used when the cables will go in behind the surface being mounted to, to get some stand-off from the mounting surface, or special situations such as pole mounting? Thanks.
