D dannieboiz Getting the hang of it May 13, 2015 498 72 Feb 16, 2017 #1 I remember reading that higher MP camera have a more narrow angle. If I were to replace a 3mp with 4mm lense, should I get a 4mp 2.8mm lense to get the same wide angle view?
nayr IPCT Contributor Jul 16, 2014 9,229 5,330 Denver, CO Feb 17, 2017 #2 your going from 4:3 to 16:9, likely you'll get wider.. why dont you check spec sheets, they list the FOV typically. but you shouldn't get 4MP, they suck when you need em the most. Reactions: hmjgriffon
K kevkmartin Getting the hang of it Aug 23, 2015 91 87 Feb 17, 2017 #3 nayr said: your going from 4:3 to 16:9, likely you'll get wider.. why dont you check spec sheets, they list the FOV typically. but you shouldn't get 4MP, they suck when you need em the most. Click to expand... For example: 4MP HikVision 4mm lens Vs 2MP Dahua Starlight Varifocal Turret
K kevkmartin Getting the hang of it Aug 23, 2015 91 87 Feb 17, 2017 #4 kevkmartin said: For example: 4MP HikVision 4mm lens Vs 2MP Dahua Starlight Varifocal Turret Click to expand... Reactions: nayr
nayr IPCT Contributor Jul 16, 2014 9,229 5,330 Denver, CO Feb 17, 2017 #5 and here's 3MP vs 2MP Starlight: Go buy a Dahua Starlight Varifocal Turret (IPC-HDW5231R-Z) then you dont need to worry about what lens to choose, it comes with all of em.
hmjgriffon Known around here Mar 30, 2014 3,369 976 North Florida Feb 17, 2017 #6 glad I paid for 3 more now, these gadamn things are selling like nuts. Reactions: cryptelli
