Okay, been using BI 4 with 34 3MP Longse IP cameras. All but 6 are 20fps and VBR. The other 6 are 30fps and CBR of 5120 (the VBR wasn't ramping up fast enough when movement was happening). I managed to get my CPU usage down to 78% using all the tricks (direct to disc, low realtime frame rate in app, etc.). I am/was happy with that usage, but thought I might be able to get it lower by turning on the Intel acceleration feature. That was a huge mistake. When I did this and restarted, my usage went up to 95%.
In trying to fix it, I turned off running as a service and restarted. This didn't help, so I turned off the Intel function and restarted. This also didn't help. I then restarted it as a service again and it lowed the CPU usage, but not to the level it was before. I now hovers around 84% and frequently goes up to 95 to 100% when one or two cameras are recording or I am viewing footage.
I need to get it back, but am at a loss. The setting are identical to what they were before the change. Has anyone else run into this issue? It's a windows 7 64bit, 5820k 6 core, 16GB DDR4, SSD and WD Black running the latest version of BI 4. I don't see why it can't use the Intel acceleration, but more than that, why it won't go back when turned off.
Thanks
Thanks
