I'm about to replace several old cheap cams that seem to have died. I have CAT6 POE running from a hub out to the camera mounts. I'm not sure if the failure(s) happened in the POE switch, the cameras, or something else.
I'm replacing the cams regardless because I'm ready to invest in something better, but before I do, I'd like to test/troubleshoot my current system so I can also replace anything else that needs replacing.
To me, this means it's time to buy a big-boy tool for proper troubleshooting.
I've been looking at these types of devices:
I'm willing to spend up to $400 for a proper tester.
But I know these are all mostly the same product re-branded or re-labelled.
Still, the negative reviews about build quality worry me a little so I'm wondering if there is a particular brand that has provided good service, support, etc. to anyone here.
Has anyone had a good experience here?
Amazon.com : Koolertron Upgraded 7 inch IPS Touch Screen H.265 4K IPC-9800 Plus IP Camera Tester CCTV CVBS Analog Tester Built in WiFi with POE/WIFI/8G TF Card/HDMI Output/RJ45 TDR/Dual Window Test/Firmware : Camera & Photo
www.amazon.com
Amazon.com : Wsdcam 7 Inch IPS Touch Screen IP Camera Tester Security CCTV Tester CVBS Monitor Analog Tester with SDI/TVI/AHD/CVI/POE/WIFI/4K H.265/HDMI in&Out/RJ45 TDR/Firmware Upgraded 9800ADHS-Plus (Red) : Camera & Photo
www.amazon.com
