E-Z Ancor "Stud Solver." It's the one DaveP posted in METAL.
The come in 40 and 50LB ratings. Available on the shelf at your local Lowe's. Home Depot has a similar product by another brand, but I don't like it as much. Avoid plastic ones as they can snap when you screw them in.
I use these Rawlplug Spring Toggles. 3mm x 50mm. They need a 10mm hole in the wall, but I mount on a small plate and reuse the same holes with a new plate whenever I change the camera. The camera mounts/screws to the plate rather than the wall.
So I bought these, and ended up not using them because they were slightly overkill. But I just could not for the life of me figure out how to screw the screw into the anchor that does into the drywall.
A:With a cordless screwdriver..? The screw drives into the 'cross' which you used to drive the anchor in.
