What SW/HW solution can compete with AXIS Loitering Guard (having smaller pricetag)?
Hi,
Can anybody recommend software of hardware solution that is similar to AXIS' Loitering Guard? It can be simple, but still having reasonable false-alarm amount, unlike, probably, Hikvision's intrusion detection. And it will be great if it can work with cameras less expensive than AXIS - Hikvision's pricetag is OK.
Background:
I'm trying to figure our what can be a solution for my 2 camera environment.
One of those is supposed to monitor 2 doors that are located nearby - private apartment's entrance door and storage room located nearby.
I would like to receive alerts only in case somebody is loitering around.
Unfortunately basic solution I thought of (Hikvision's loitering detection) has limited configuration, so any object that stays in the view for more than max 10s should trigger alert.
In reality pretty often it takes more than 10s to come to the door, find key, open door, enter apt, close the door. Thus I expect that Hikvision will trigger a lot of false alarms from my family members coming home.
As high-end alternative I've found AXIS' Loitering Guard that from first glance looks like really robust solution with all it's settings.
Downside is expensive cameras plus small extra for this plugin.
Unfortunately for me they're very expensive. And I can't find used ones in my area.
Pls, advise.
Hi,
Background:
Pls, advise.
