What resolution sub-stream should I use for AI analysis
105437
BIT Beta Team
Jun 8, 2015
2,324
1,142
I've been testing the built-in AI using the main stream and it's causing CPU to peg in certain scenarios. I'd like to try using the sub stream to help with this. What resolution for the sub stream would still allow for good AI analysis for people, vehicles and animals? Thanks
Snapshots sent for analysis are resized automatically to 640x640 pixels (the standard default input size for YOLO object detection models) regardless of whether your camera source stream is 1080p or 4K.
Because of that, it will struggle the further away objects are from the camera.
Reactions: 105437
So using the sub stream for AI that is set to 704x480 (D1) should be okay?
