I've been doing various searches and there is a lot of mixed info out there.
Currently I have these three ports opened up and it is working properly, but I want to shut anything down that's not required:
Port 80 TCP
Port 8000 TCP
Port 554 TCP and UDP
If I'm not using a NVR and just viewing the cameras via the Hikvision movile app, shouldn't the app only need to access to 8000? Or does the app use the RTSP stream (554)?
Or is port 80 needed if you are going to make any changes to the camera settings (are changes sent via http posts)?
Is there any info that describes exactly what each port is needed for?
One site mentioned port 1024 is needed for 3G/4G which is really misleading and definitely not needed.
Thanks
Port 80 TCP
Port 8000 TCP
Thanks
