Hi!
I have been searching for a general guide to what NVR software is compatible with what cam software - but so far in vain.. Maybe someone here can help?
Sorry if this topic has already been covered a trillion times; I have just not been able to find anything authoritative in this regard..
My setup: A HikVision 7608NI/SE, with 5 x HikVision DS-2CD2132-I 3MP cameras. 4 of the cams are connected directly to the NVR's 4 PoE ports; the 5th via a PoE port on a TP-Link TL-SF1008P. The NVR is connected to the LAN through the TP-Link switch (on non-PoE ports). Cams have firmware V5.1.0 build 131202.
For various reasons, I am sticking with (stuck with?!) NVR firmware V.2.3.7 build 131211 for some time to come. I have noticed that cam firmware 5.2.0 is now out.
My question is:
Is there any point in upgrading the cam firmware? Can the NVR actually "benefit" from it - i.e., will the features available actually change, or is everything anyhow determined by the NVR (firmware) (so the cams are just "dumb"), when the cams are connected to such a contraption? Or will the NVR no longer recognize the cams with a more recent firmware?
Oh, and the bonus question: I assume that IF I upgrade, I will have to use TFTP to upgrade the cams - i.e., connect a PC to my PoE-switch, set the IP-address to something meaningful (SADP reports that the cams are on 192.168.254.xxx, so I would have to set my PC temporarily to e.g. 192.168.254.100, right?), and then TFTP the firmware to each of the cams ??
Thanks in advance for any help! Sorry for being a newbie!
My question is:
