What kind of camera post is this @ Playboy Mansion?
Frangeech
Jul 10, 2020
2
5
New Jersey
What kind of camera post is this at the Playboy Mansion? I'm looking for similar mounting solutions to deploy around a property, do you know where I can find something like this? Everything I come across is the traditional square aluminum pole very industrial looking.
Reactions: garycrist
To me that looks like pieces of plumbing pipe. You can see the "ells" where it bends. I have no idea what the bell or dome is from though, although it probably is the upper housing of the camera itself. The big trick is adapting US sizes to metric sizes to get the pipe to fit the camera housing/mount. I guess you could re-thread either the pipe or the camera to get that accomplished.
I was thinking plumbing pieces as well based.
NOTE: This below is from a post I made in another thread last year for a different purpose but the idea is similar, allow for mounting from the top as in your post. Also, you would likely want to size up from 1/2"; condulets and conduit fittings are available in several larger sizes (3/4", 1", 1-1/2", 2", etc.)
How about a 1/2" pulling elbow near the cam, connected with a short, galvanized steel 1/2" rigid nipple threaded into the rear of the junction box on the back of the cam, then another galvanized steel 1/2" rigid piece from the the other end of the elbow to the floor flange which is bolted to the horizontal surface?
These below are U.S.- based stores but you can find at hardware stores in your area I'm sure.
Halex 1/2-in Aluminum Pull Elbow Conduit Fittings
Mueller Proline 1/2-in dia Galvanized Floor Flange
Oh we know need a comparison video from the camera and the Ring LOL
That beep beep beep beep beep beep is the reason I came here, that beep beep beep beep beep
Reactions: sebastiantombs
Just a reminder, these cameras can be mounted in just about any orientation. A "cleaner" looking install would be to use the correct size Dahua junction box and run your conduit into it (it will screw into the holes with the right adapters). If the box is mounted vertically on a wall, the camera can still be mounted to the box and the camera ball adjusted to provide a regular view without any software shenanigans required to make it look right.
As far as the OPs question, I agree that it looks like a homemade mount made up of various pipe/conduit fittings. It's both impressive and laughable at the same time. :idk:
Thanks for the input, much appreciated. I'm here to learn :) , jack of no trades, master of none, ;)
They also make a wall mount bracket for some of their cameras. Looks like this.
