- Jan 3, 2016
- 67
- 6
Hi,
I am looking for a cam to put inside my garage.
I have seen the HDW4231EM-ASE which looks good but maybe overkill for looking inside my garage.
Then I found this HAC-HFW2231S in EmpireCandy alisite, which seems to be a starlight cam, and is cheaper.
HAC-HFW2231S | Dahua Technology - Dahua Technology
I tried to find a test of the latter one, with no luck.
What do you think? Is the 2231 good enough to put inside a garage?
The only issue I see on this cam so far is its lack of PoE support... But is is 40€ cheaper than the 4231.
Aliexpress.com: Acheter Dahua HAC HFW2231S 2MP Starlight HDCVI IR Bullet Caméra, livraison gratuite de bullet camera fiable fournisseurs sur Empire Technology Co., Ltd
