What is N1 Protocol? HI3536D based NVR
rec.fpver
Oct 2, 2019
11
2
nz
I picked up a cheap china wireless IP camera set for a friend.
Bought locally for about us$70 equivalent. 4x wireless/wired cameras and recorder. No hard drive.
NVR is HI3536D based.
Camera I did not take apart yet. Mac address does not return manufacturer. 00:9a:15
Straight to the point for tl/dr crowd, fluff later in the post.
A wireshark capture between the camera and NVR shows HTTP encapsulated RTP?
Code:
GET http://192.168.1.191:80/livestream/11?action=play&media=video_audio_data HTTP/1.1
User-Agent: HiIpcam/V100R003 VodClient/1.0.0
Connection: Keep-Alive
Cache-Control: no-cache
Authorization: Basic YWRtaW46
Content-Length: 59
Cseq: 1
Transport: RTP/AVP/TCP;unicast;interleaved=0-1
Code:
Session: 3
Cseq: 1
m=video 97 H265/90000/1920/1080
m=audio 8 G711/8000/2
Transport: RTP/AVP/TCP;unicast;hisiinterleaved=0-1;ssrc=00000003
Tried forcing VLC into this mode but failed to get any images.
Port 554 was open so I tried a few URIs for Hisilicon. No go.
Telnet was also open so tried a few logins. No go.
Wireshark capture of the webpage stream does not help much either.
It uses a flash app?
Code:
GET /images/swfupload.swf?preventswfcaching=1571157185536 HTTP/1.1
Accept: */*
Accept-Language: en-NZ
Referer: http://192.168.1.191/view.html
x-flash-version: 32,0,0,255
Accept-Encoding: gzip, deflate
User-Agent: Mozilla/5.0 (Windows NT 10.0; WOW64; Trident/7.0; rv:11.0) like Gecko
Host: 192.168.1.191
If-Modified-Since: Tue, 15 Oct 2019 16:33:45 GMT
Cookie: juanipcam_lang=en; login=admin%2C; sync_time=true; usr=admin; pwd=
Code:
GET /netsdk/image?r=0.012618570360721726 HTTP/1.1
Accept: application/json, text/javascript, */*; q=0.01
X-Requested-With: XMLHttpRequest
Accept-Language: en-US,en-NZ;q=0.7,en;q=0.3
Host: 192.168.1.191
ONVIF Device Manager didn't get anything out of it either.
The alternative is if we can pull a stream out of the HI3536D NVR. Even if it is in the quadview screen.
At lease processing will get us into the general timeframe of the icendient.
Any help appreciated :)
First impressions.
The cameras felt the part, all plastic and light.
Not sure how long they will last in the sun.
For the price if they go 2 years I will be happy.
The picture was surprisingly good. Day and night.
It was truly plug and play.
With open door security ;)
Camera settings were locked down. Only basic ones available. No manual shutter range so no good for night LPR application.
The downfall with any cheap NVR is playback.
Motion detection outside fails miserably with any vegetation nearby.
I wanted to run them into something a bit more smart.
My program of choice is Sighthound.
The amount of time I have spent working on this I could have bought a few Dahua cameras.
But I persevere on principal and a good learning exercise :)
That is correct. But VLC supposedly supports H265 since v2.1.1
Current version is 3.0.8
Will try other software just in case.
Telnet prompt attached for future reference.
Tried Blueiris.
Looks great in wireshark.
Correct handshake. Request. Stream starts.
But nothing shows up in BI.
I did turn off hardware acceleration per forums post.
Would the N1 protocol specifications be posted anywhere?
Since it is specifically mentioned as supported by the HI3536D specs I wonder if it buried in some technical document somewhere.
This brand is Xiongmai OEM.
Hi,
Finally did you find any way to connect directly to those cameras? I have a similar camera and looking how to get the video stream via rtsp
I think I can help you. I have similar cameras and I am able to get them working on VLC and Zoneminder for my use case.
First, follow these steps on your VLC player to change the dmuxer to H264 video.
Then use below link in VLC stream
You should also be able to curl to the video url on a linux terminal and GET output file in this way:
curl '' -o sample_video.mp4
Let me know if it doesn't work for you.
