S spyfly81 Getting the hang of it Dec 27, 2014 133 7 Dec 12, 2015 #1 I am looking at cameras on AE and they have option for either 380tvl or 480tvl, is this 2.8mm and 4mm? I am looking at these IP cameras http://www.aliexpress.com/store/pro...F-Support-Waterproof/1627277_32488273439.html
bp2008 Staff member IPCT+ Member Mar 10, 2014 12,900 14,496 USA Dec 12, 2015 #2 Usually that is how it works, but I don't see them specify here. Best to ask the seller.
fenderman Staff member Mar 9, 2014 36,891 21,408 Dec 12, 2015 #3 spyfly81 said: View attachment 6908 I am looking at cameras on AE and they have option for either 380tvl or 480tvl, is this 2.8mm and 4mm? I am looking at these IP cameras http://www.aliexpress.com/store/pro...F-Support-Waterproof/1627277_32488273439.html Click to expand... Its meaningless, its just a way to select the lens size because ali does not have a choice for 2.8mm or 4mm...the product description needs to tell you which one to select for the proper lens size to be shipped.
S spyfly81 Getting the hang of it Dec 27, 2014 133 7 Dec 12, 2015 #4 that is what i figured that is was a way to select a lens, thank you
Q™ IPCT Contributor Feb 16, 2015 4,939 3,987 Megatroplis, USA Dec 12, 2015 #5 Their database blows and they are forced to use predefined tvl labels to identify mm lens sizes. Reactions: fenderman and spyfly81
