Had my cube cam working ok and was playing with some image settings and unplugged it from the stand alone POE injector I power it with for wifi. I plugged it back in again and get no signal. My netgear router shows in the IP on the wifi side of "cp_server.disabled = fals1". I can plug it into the network POE injector switch and it comes up fine on the reserved IP of .11 as a hardwire device and I tried looking at the wifi setting and don't see my mistake. Should WPS be on in the wifi page? it defaults on with generated password and off or on seems to make no difference. In the wifi cam config page it shows my network, managed, and the correct password.
I am sure its something simple but I cant find it.
On a positive note I put up and configured my second outdoor cam a 2CD2142 dome and it looks great. Need to adjust the aim on it and it shows up fine on the app.
Gotta go to work and I will check back from there.
Wrong part of the forum. Sorry. Will mod please delete.
