EyeseesAll n3wb Jan 15, 2021 10 9 Philadelphia May 23, 2024 #1 Random buttons were pressed on my keyboard. I would like to return to the main console screen (with all cameras). I am not finding the correct combination to do so. Maybe this screen will help someone help me!? Thanks
L ludshed Getting comfortable Sep 14, 2022 649 822 Us May 23, 2024 #2 Did you try turning it off and turning it back on?!! Reactions: bigredfish
wittaj IPCT Contributor Apr 28, 2019 30,862 59,228 USA May 23, 2024 #3 You are in edit mode. You need to select edit layout which is the option next to the gear icon in the top right. Reactions: Broachoski
Coldair IPCT+ Member Sep 19, 2015 1,061 1,363 Naples Fl May 23, 2024 #4 click here Reactions: Broachoski
looney2ns IPCT Contributor Sep 25, 2016 16,321 24,225 Evansville, In. USA May 23, 2024 #6 EyeseesAll said: Thank you. That did it. Click to expand... Based on this and your other question, you need to spend some quality time studying the built-in Blue Iris help file. Reactions: 105437 and EyeseesAll
