What can I change to improve ability to identify teenage delinquents
Cold-Lemonade
Pulling my weight
Apr 1, 2021
165
135
Boston
The footage below was captured on a Dahua N43BU83 in ambient lighting conditions. The primary purpose of this camera is to watch the front facade of my rental property from the north side in case of property crime (I have a similar camera watching from the south). Because of the camera's perspective, I also capture stuff happening on the street. As you can see from the clip below, it is not easy to identify those engaged in criminal activity at night. What settings should I try to adjust to improve the ability of this camera to capture a crisper image at night? Would EmpireTech's IPC-Color8M-TL do a better job? I am open to all your suggestions.
View attachment front_north_21cm7j.mp4
Generally speaking two things
1- on that camera you need to run a faster shutter speed. Freezing the perps results in motion blur. It will get a little darker, that’s the tradeoff. What speed (exposure) is it set at now?
DNR (noise reduction) also plays a part. The higher the more blur. What is it set at?
By the way, thats a cheap camera with a cheap sensor.
I would look at one of the below models (* They each have bullet versions which in most cases are better in that they have added lights and better
DOF but many prefer the turrets due to aesthetics.)
Most popular
Normally we wouldnt suggest 4K becasue most have too small of a sensor, but this one has the big 1/1.2" sensor and should do well with that street lighting)
New but solid performer and even better than the 5442 at light pickup at night
2- more importantly you’re seeing why relying on a single camera to do too many things doesn’t work.
That camera is good for Overview but you need a 2nd camera with more optical zoom if you wish to ID people on the street.
Recommend this one
Most everyone gets to this same point. You can either live with just having ID coverage on your own property, or add cameras with more zoom if you want to cover the street
Home_Drive-5442H-ZHE_main_20241228183324_@1.jpg Home_Street-5442-Z4-S3_main_20241228183325_@1.jpg
Home_Drive-5442H-ZHE_main_20241229115228_@1.jpg Home_Street-5442-Z4-S3_main_19691231190000_@1.jpg
The image below illustrates very well what was said in the above 2 posts about a small sensor and a slow shutter speed.......motion blur. :wtf:
Believe it or not, there's ghost perp inside the red box.......
Also, regarding any overview cams.....if at all possible, mount lower (8 ft. min to 10 ft. max) unless your local PD has a database of images of the tops of perps' heads and ball caps. :cool:
I can see where this would be a challenge due to the property sloping upward as you go from the street level to your doorstep so I guess it's just not feasible. :confused:
