hi to all i`m new to this forum.
i have an NVR hikvision NVR, 32 Channel, 320 Mbps, 24 Port POE [HIK-DS-7732NI-I4/24P] the cameras are directly connected to the NVR poe ports, and directly on the modem.
what can i do to prevent from the NVR to be hacked, it is accessible through external ip, as i forwarded the ports to be able to see it from the mobile / laptop.
is there any hardware that can be installed between the modem and the NVR? or is best to use a dedicated VLAN? but this is used in domestic house i.e. the only swich is the modem provided by the service provider.
appreciate your input.
thanks
thanks
