- Jan 28, 2017
- 1,211
- 472
There are a lot of great threads that talk about securing you camera but some of the step by step instructions that really help the noobs like myself are mixed around. I wanted to make a thread to share my experience with setting up stunnel so it is all in one place.
Knowing why you should secure your camera really helps. Thank @nayr for creating the awareness:
VPN Primer for Noobs
Quick second to thank a lot of great forum members here that create informative threads/posts or even helped me with questions through PM:
@fenderman, @Mike, @looney2ns, @Dasstrum, @Walrus, @TonyR, @bp2008 @SouthernYankee - I probably missed someone.
I am currently using Stunnel to connect my BI computer to my BI app.
Download the Stunnel program here:
stunnel: Downloads
Most will need to download this file from the link above:
"stunnel-5.55b2-win64-installer.exe - 30th May 2019"
Or whatever is most updated file at the time for win64
This video by @Dasstrum will get you started and suggest watching it first:
*NOTE* in video disabling TLS 1.3 doesn't always allow you to connect to UI3 in Chrome.
@Walrus figured out that you can use zerossl website to create a self signed certificate (see setup below this video):
Website used for SSL:
Free SSL Certificate Wizard and other SSL Tools @ ZeroSSL
See steps below to set this up:
Issues:
Sometimes GUI gives you issues on restart - @Walrus has some tips here to get it to work:
Pros:
-Do not have to open any other programs once this is setup
-No need for any other phone apps except for Blue Iris
-No need to setup anything on your router
-Easy setup with a few steps
Cons:
-Requires custom SSL to get UI3 to work with chrome
-GUI can be glitchy after computer restart for some
-You need to forward a port on your router
More info in this thread:
stunnel
Share what setup you are using. Please list what you did and used: website, app, programs, products, any issues you ran into and how you fixed it. Please credit any other Forum Member & threads that helped you with your setup.
PM me or post here if I should add/remove anything about setting up Stunnel and I will edit it in this post to have it all in one place.
Thanks
stunnel: Downloads
After hours of frustration, finally solved it. I used the website Free SSL Certificate Wizard and other SSL Tools @ ZeroSSL to create a new self signed certificate, and put my no-ip domain as the domain. This generates key.txt and crt.txt files. You then open the old stunnel.pem file, and replace everything in the file using both the key.txt contents then the crt.txt contents in that order.
This includes replacing the -----BEGIN PRIVATE KEY----- and -----END PRIVATE KEY----- parts, as the new key from zerossl uses -----BEGIN RSA PRIVATE KEY----- and -----END RSA PRIVATE KEY----- instead.
It now works with both the updated version of chrome on my android phone, and chrome on my work computer.
Issues:
The Stunnel program is a bit of a mess to get working. I find it works as follows:
If you have the service running, you can't run the GUI. If you do run the 'Stunnel GUI start' program with the service running, it will say the service is down.
If you stop the service , you can run the GUI. You can keep the GUI running, and stunnel will work.
To start the service again, you need to stop the GUI with the 'Stunnel GUI stop' program and run the 'Stunnel service start' program.
Upon a windows restart, whatever you had running (service or GUI) will run again.
Pros:
Cons:
stunnel
Thanks
