What are you doing with your images? How are you offloading them?
Ri22o
2,350
4,618
Indiana
Now that both LPRs are running and using CP AI, I am getting a very full Alerts folder. There were so many LPR files in there in a short amount of time that it caused all of my other alerts to be deleted. I ended up with only being able to go back about 5 hours on the other cameras and see about a dozen alerts.
What are you doing to keep your LPRs from clogging up the rest of your system alerts? Is there a way to have the LPR alert files put somewhere else? Am I using the wrong setting on the Trigger tab? How do you offload your images for a database?
That does not sound right. I have no issues like that. My Alerts are 60 days old. They are on an SSD called 'D' which is a WD Blue 500GB NAND SATA III.
I am running BI 5.7.3.0
My Alerts folder was only allocated 1GB and a 7 Day limit, I increased it to 60GB after noticing this issue.
I was also just curious how people are separating the LPR plate captures and sending them to a folder of their own, or if this is even possible. If possible, it could reduce the needed size of my Alerts folder.
I do not send the plate caps to a folder of its own. They are just the normal Alerts .
