I understand why a wall mount would be necessary when installing, say, a turret cam, so that the cam wouldn't be sideways. However, when installing a turret on an eave or installing a bullet cam, would there be any benefit to using a mount rather than just mounting the cam directly to the building? The fan favorite 5442T-ZE has a water ingress rating of IP67, but its PFA130-E mount has a lesser rating of IP66. So, unless I am misunderstanding, this means that the 5442T-ZE has greater water resistance when installed without the junction box. I also understand that with some mounts, the pigtail can be stored inside the mount, but if the wires are going inside a wall anyway, does that even matter? Water resistance doesn't equal water proof, and I'd think it would be preferable to have the wires, including the pigtail, inside a wall, even an exterior one, than inside the camera mount.
Basically in the cliff notes, "it is recommended to purchase a junction box or mount from the manufacturer along with your camera," and I'm just wondering why that is the case. Thanks.
