I suspect this is something that may have become corrupt in Windows 10. It seemed to start several BI updates ago. I thought maybe the next stable update might fix it but it didn't. I dreaded reinstalling BI to try and cure it but the reinstall went very smoothly, however I still have the problem. I'm just curious if anyone else has encountered this.
When moving through the BI alert list, which I do very often, I use the BI console. It is very erratic, using the up or down arrows, if I arrow up or down it jumps back to where it was before I arrowed up or down. I can do 3 or 4 quick arrows up or down and it returns to where it was. Sometimes it will behave for 5 or 10 movements ok, then start again. I have tried changing the sort order, changed icon size in alerts list, tried changing from my bluetooth keyboard to a usb keyboard, no joy. I may be forgetting other things I've tried. I do not see this problem using UI3.
At this point it is just very annoying, I think at this time I would rather live with it than reinstall Windows. I haven't noticed anyone posting with this issue but sometimes it depends on the way you word your search.
