I have a setup with a Dahua NVR 5208-8p an 4 camera's IPC-HFW4300S a SD22404T-GN and a IPC-HFW4431R-Z.
I replaced the nvr with a 5208-8P-4KS2E from Andy, now when I connected the camera's only the SD22404 and the HFW4431 came on immediately, the other 4 camera's I had to change the setting to ONVIF before the image showed up. ( the other two are showing private and worked immediately).
Now the problem is after a couple of day's the 4 camera's change themselves to Private and there is no connection, when I change the settings again to ONVIF they connect and give an image.
How can I make that they don't change again ?
Thanks for any advice.
