I am deploying a new router (TP-Link A20 tri-band) and rebuilding my BI setup (still on v.4) and everything is back, except the webserver just doesn't work. The main BI server that I have running as a service works fine... the native BI software on the host PC works fine... UI3 in a browser on the host machine works fine. But it will not route anywhere outside of the host machine, not even to other PCs or devices on the same LAN. All other connected devices and Internet service is fine. Never had this particular issue in over 10 years of BI use. If I click the Windows network diagnostics it reports the server is there but is not responding.
Any ideas what to check? I have tried with all the router security to include the firewall off. No other blocking or prioritization engaged. Pretty much just starting with the basic default router config with my wifi info entered. Also looks like the VPN is going to be problematic. I never had any issues with my old Linksys for VPN. Worked first time/every time. No luck connecting the VPN up with this router yet. :-( Next step is to save my BI config, delete the app, and start over. But I really hate to do that. If I do I may upgrade to v.5 whilst I am at it.
Here is a photo of the web server setup. I have tried other ports, didn't make any difference.
