Webserver error logs 403
grottoguy
Apr 3, 2022
2
United States
Hello. I've got a reverse proxy in front of BI, going across a wireguard tunnel.
It appears that BI is blocking access with a 403 based on IP address.
I've enabled the wireguard tunnel address as well as the originating reverse proxy, but still not working.
I need to be able to see what IP address BI is blocking at its webserver level; for instance, maybe the tunnel is passing a different set of IPs than I expect, or the reverse proxy is somehow using the client's IP all the way to the BI server.
I imagine I have a simple config error in the BI webserver access control, but it would be very easy if I could find the webserver error log and see 'IP address x blocked'.
Anybody know how / where that can be turned on or accessed?
Thanks
