- Feb 18, 2017
- 7
- 1
Good morning everyone
I am running a Dahua NVR4432-16P with the following version info:
Web Version: 3.1.0.66469
System Version: 3.203.0000.0.R
Build Date: 12-06-2017
Onvif Client Version: 2.4.1
My IP cameras are plugged into the POE switch of the NVR - previously the cameras I wanted to set up were plugged into a separate POE switch as I was under the impression that was the only way to access and set up IVS rules on them.
Since this firmware upgrade, it appears to have a new section under 'Camera' --> 'Registration' with a link to the web interface 'Web Browse'.
Now when I use that link it takes me to a secondary web interface of the individual camera, I can log in etc and the webplugin.exe prompt is given again. Now this works fine and I can view video etc in the NVR's web interface but I continually get an NSIS error when installing through the camera interface...
I have tried running as administrator from within Windows 10, and command prompt install also but still get the error.
Anyone have any suggestions on how to get this to work - as I'd rather have the cameras plugged into the NVR switch if IVS is possible now with this firmware.
Or perhaps if anyone has the executable file I can try installing from there in case for some reason the download from the NVR is corrupted.
Cheers
Troy
Cheers
Troy
