Hi there,
I own four HWC-C120-D/W IP-Cams.
The only difference between them is the build-no. of the Firmware.
I have no problems with the two Cams with the Firmware build beginning with 18xxxx, but there is no Chance to enter the Webinterface of the two Cams with the Firmware build 171115 :-(
If I enter the IPAdress of one of the two the following Error Message appears:
Access Error: 404 -- Not Found
Can't locate document: /
With the other two Cams -> no Problem = the Login Screen of the Webinterface appears.
I manged to configure the two Cams via the iVMS-Software, but I wonder if there is a way to upgrade the Firmware or if there is another way to enter the Webinterface (if ist present in the 171115 build)?
Cheers
Cheers
