- Mar 2, 2015
- 14
- 0
Hi all,
I am wanting to setup a Windows Media webcast using Blue Iris with my IP hikvision DS-2CD2532F-IS.
Everything seems to be working fine on a "Video only" webcast setting, however, when I do "Audio and Video" webcast under the Windows Media settings, it works for a short while (from the webcast end) and then the Video stream ceases. THe audio stream seems to continue however.
In the actual Blue Iris side of things, it continues fine.
Sometimes after this point, if I restart the cameras, they refuse to restart and I have to "End Task" and reboot the BI software to get them back again.
"Video only" webcast seems to work fine.
I must have tried a billion different settings here and still don't seem to be getting anywhere. I just can't seem to figure out why the "Audio and Video" webcasts die after a short time.
URLs to my IP camera I'm using are:
IPADDRESS/Streaming/Channels/2
But I have also tried various other ones.
Also, on a side note, but potentially related, what's the difference between the Main Stream and the Sub stream? I can see that generally the settings for the sub stream are inferior to the Main Stream. What's the purpose of the sub stream?
Thanks!
Daniel
Thanks!
Daniel
