Webcast Youtube Main Stream vs Sub Stream?
Apr 5, 2016
8
21
Does anyone have any insights on getting BI to webcast a cameras main stream rather than the sub stream to YouTube? I've struggled with this for a while with no luck. There are some old posts here referencing a how-to on another site that is gone but otherwise I'm not finding much discussion of this. Appreciate any insights. My settings below -- but stream is the sub, not the main (or rather it is very low res. If I remove the sub stream from the camera setup, then the main stream shows up in YouTube. I realize I can setup another instance of the camera but this ends up duplicating the streams coming into BI and complicating my setup so I am hoping to find a solution w/o setting up another instance of the camera in BI.
Check the encoding parameters (that ... button next to Flash 0). if I were you I would tell it to resize the output frame to exactly the size of the main stream and see if that works.
You'll need to contact support then and let them know it is broken.
Does your camera have a 2nd substream with like 1080? I found that some of mine do.
The camera I'm interested in webcasting to YouTube doesn't have a higher resolution substream.
Posting here to see if anyone has this working with a high resolution main stream? I tried support w/o a lot of traction a while back so hoping someone here has direct experience with getting this to work.
