I do have an old Foscam I will try it with but that doesn't help if we want it in HD with current cams.
Alright I have made some discoveries ...
It seems like the YouTube streaming requires audio. I was able to use any video size and the default encoder settings. If there was no audio, YouTube would not process the video.
I did find a bug where I enabled audio in the camera window yet no audio was flowing, since the camera had no real audio stream. I fixed this so that it setup a silent/empty stream. YouTube is happy with that!
I will have an update within a day in case this will help your situation as well.
Thanks
Ken
I have not used live streaming before and would like to try it.
Has anyone by chance posted step-by-step instruction on how to set it up through YouTube or U-stream, direct from a camera or through BI?
Is this free or are there any fees involved to do this?
I got it to work for a few minutes. Then constantly going offline.
Art Thompson Birdcam - YouTube
For Ustream create an account, go to channel setting and create a channel.In broadcast setting you can find encoder settings with url rtmp and key streaming that you must insert in BlueirisI have not used live streaming before and would like to try it.
Got it Working by Enabling Audio on the Camera you want to broadcast! Just click the Audio Tab and enable.
Max B frames should be 1
GOP frames as 30
Superfast, HLS 3
I used OBS to stream to Youtube but had issues with the feed hanging at random times. Will you post what you did to achieve a successful Youtube link up? How long has it been running non stop?
I do have a BI/Youtube stream running now at: Bird Cam – usefulramblings I'll see how long this streams.
