Yesterday I lost power for about 4 hours. When it came back on, I found that my Blue Iris machine was not able to use its normal IP address because something else on the network took that address. So I set it to use a new static IP locally. I went through the web server setup wizard in BI again to make sure it was working. It passes the internet connectivity test, then I see this error:
I click next again and the remaining steps all work fine. I can access the web server fine over the LAN while I'm at home. But accessing remotely is extremely slow and often won't connect at all. Any ideas on what I need to do?
