I upgraded to the latest version of BI6. I can't get the web server to work on BI6. It was working on BI5. I have been using the BI mobile app to connect remotely. MY actions:
1: I have access to the Modem.
2; I have been stepping my way the the Remote Access Wizard.
3: I have been green check marks at all of the steps until I get to the UPnP step.
The router address on the LAN and the internet/wan address appear to be legit
I can load the BI webpage and it appears to work fine.
The listening ports seem to work. I get a green check mark.
4: Things seem to fail on the when port forwarding to the modem. The wizard gives me no sign of a problem until try to actually connect on the next step it says "unreachable".
The UPnP list looks to be ok on the Modem. It also seems correct in the PortForwarding. It has the right port and address on the Lan Address is correct. I have saved everything and rebooted the modem a couple of times. Still no connection.
The directions in the Wizard and its documentation are hard to follow at this point. I am thinking the modem his not set correctly. Do I need to reset something else in the modem that UPnP that BI did not do in UPnP ? This has become really frustrating. I am at least 6hours into the process. If I were to set up NGROK tunnel would that be easier? I think I will try a couple of different listening ports next.
Any and all ideas will be appreciated.
