When I run the web server wizard, I get to the page where it performs a final test, and once or twice it passes but most of the time verified server says "The remote server returned an error (404) not found"
I am using port 81, and I have checked canyouseeme.org, it says I can see your service, your isp is not blocking port 81.
I thought it was due to the WAN IP changing too often, but tonight I tested again, directly after it worked and it did not pass, with the same WAN IP.
I have even tried setting NO IP, which works and allows the mobile app to connect, but only when BI passes the final test.
Any ideas? Is it a BI issue maybe?
