I've found a nasty little bug in the 5.4.4. release of the firmware related to the Scheduled Day/Night switch.
On 5.3.8 I had my 2CD2342 set up so that during the day WDR was ON and Noise Reduction OFF and then at night WDR was OFF and Noise Reduction was ON.
This worked well as the WDR is not helpful in dark scenes as it just introduces noise and washes out the image.
Since updating to 5.4.4 the camera will no longer switch back into the Day settings, in particular switching back ON the WDR. Now when the camera transitions from Night to Day the WDR settings do not take effect leaving the captured image dark and with any shadows completely lacking in any detail whatsoever.
I should add that all other settings seems to transition correctly. I've narrowed it down to the WDR setting that seems to get stuck in night mode.
I've tried a number of different things but nothing has resolved the problem so far. Even moving the WDR level slider in the camera settings won't switch on the WDR when it gets stuck in the night mode setting.
Simply rebooting the camera correctly sets up the WDR settings daytime as configured.
This is a real problem as I have a lot of areas in shadow during the day with a lot of corresponding bright sunny areas. Without the WDR to assist in daytime it's useless.
If anyone can suggest a solution to the problem would be appreciated.
