Well, my fake rock is good at looking like a rock:
but it's also good at holding in moisture. After our wet winter, 2 of my cameras stopped working. After troubleshooting everything else ♂, I pulled up the rock, and it's soaking wet underneath:
So I have 4 strings of Cat5e coming up out of some conduit, and I made the mistake of punching those down into two of these basic 2-port, surface mount boxes that do nothing to protect the circuits.
Then I have 4 short cables plugged into those boxes and running up the mailbox post to power the cameras. I'm actually surprised that the remaining 2 cameras are working.
What's a good solution for junctioning 4 cables down there? Originally I used those boxes because I want to be able to easily disconnect/reconnect/test/reconfigure things out by the mailbox, but it turns out that was a bad idea.
I could re-terminate everything with 4 of these couplers:
but then ideally I'd need way to mount them to that wood block, just to keep them from descending all the way into the mud.
Any other good ideas?
Thanks!
Thanks!
