Waterproof connector for Dahua cameras
d5775927
Getting comfortable
Dec 11, 2019
404
329
Israel
I lost the waterproof connector that comes with Dahua cameras.
Where can I buy one that fits the female plug of a Dahua camera (or does it have an official name?)
upload_2019-3-13_19-20-53-png.40384
I know you are all refreshing for the lottery results. so guessing there is more change for me to get an answer now :wave:.
Search for "rj45 connector cap" on ebay and you'll get a lot of hits. This type of connector exists in different diameters, but since the ebay hits specifically say they're for security or network cameras, I'd hope they are the correct size.
I have used a couple from this kit
BTW if you are doing new ethernet terminations, I absolutely love the new pull-through RJ-45 CAT6 plugs. SO much easier than the standard plugs. Strip a longer length of wire and once they are arranged in correct order, cut them on a 45 degree angle to more easily pass through the plug. With the wires pulled through it is simple to verify order and pull up all the slack to minimize untwisted length. RECOMMENDED
