I'm currently in the process of building a house, it's nearing lockup stage. At present, I've laid all the cables, 50+, and they all originate from a storeroom under the stairs. The storeroom is yet to be plastered.
I have an 18RU Wall-mounted rack with a swivel unit, the unit can open up and be swung right so makes for easy access to the rear if need be. I'm now thinking about the best or most ideal way to put the cables into the rack.
1. Enter from the top of the unit, therefore the cables can be seen entering from above. Under this option, the cables would either drop down from a ceiling hole or from a wall hole near the ceiling.
2. Enter the rack unit directly from behind, therefore no cables seen and effectively locked away.
3. Enter the rack from underneath and have the same issues as point #1 above, except the wall hole will be close to floor level.
I'm am tending towards option #2, not having any cables visible. This option also makes it a little harder to maliciously cut cables.
I'm wondering if there is a possible gotcha or something I haven't considered could be an issue. Any suggestions welcome.
Steve.
Steve.
