A quick question about this setting as I'm getting quite a few sunlight false alerts ....the sun can change quite rapidly over a few seconds on some steps I have monitored which is causing quite a few false alert...
So if the sun changes from dark to very bright in under 3 seconds and I have x and y set to 2 times in 3 seconds ...I take it nothing will happen ?
Is it as simple as that ?
Also if I then have a man walking down the steps and he is in motion for plus 3 seconds ..I should get an alert
Is this correct ?
Is this correct ?
