Hello everybody
I am new in this forum, I have read a lot but I can't find the solution.
Currently I have installed a VTO2202F-P and a VTH5321GW installed through the Dahua SIP works correctly, but I'm trying to install it with Asterisk, in order to integrate it with home telephony.
The problem is that when I make a call, I can't hear it properly, either between the two devices, or with a SIP client on the computer or smartphone.
From what I have found, the VTO uses a G711U codec and in Asterisk I have ULAW enabled and configured in the extension.
All extensions are with CHAN_SIP, as I understand it doesn't work with PJSIP.
Does anyone have this problem?
Thank you very much for your help
