The problem I have is 'custom audio/video encryption'. I made the silly mistake and turned it on ages ago.
Now when I turn it off the VTO still asks for login authentication to view it but actually doesn’t work when you use the last password you had, even though the feature is turned off.
It’s like the 'custom audio/video encryption' is stuck on.
So I have to turn 'custom audio/video encryption' back on to get functionality working and can view the VTO stream but with login authentication only.
Then when someone pushes the Doorbell (VTO) if I wish to see the live video I have to use login authentication (password) to see it, which then takes so much longer then it should and half the time it just crashes the DMSS app.
With this problem I have tried everything from factory reset everything (multiple times), delete DMSS account (multiple times), create another DMSS account and still cant get the 'custom audio/video encryption' feature to disappear completely like it was when I first installed everything.
If anyone has any info on this, please let me know.
