VTO record to NVR
Opeth
Sep 15, 2019
214
36
Cyprus
Hello all
Anyone familiar to this?
I will install to a house the dahua NVR4104HS-P-4KS2/L with 3 cameras and a VTO2202F-P-S2 and i m wondering if i can set this to record to NVR and not use the sd card for the VTO.
thank yoy
Yes, the NVR can record.
Add the IP of the VTO to the NVR and it will register. You might even be able to use the automatic search (since it's a Dahua device).
The person in this video is using an XVR (records analogue and network cameras) but you have an NVR so it should be able to use the POE switch built in.
The doorbell monitor can also be setup to show all the cameras the NVR has.
I will connect the vto and vth to a different poe switch and the cameras at the built in poe switch to nvr. But all at the same network.
Reactions: Mark_M
I get a lot alarm of door contact and im not using a door contact. How can i disable this alarm.
