I have an Orbi RBR750 router and followed the instructions and can not get it connected to a windows 11 computer. What’s the easiest way to setup a VPN? How do you have your VPN setup? I have a new Dahua NVR that I want on a VPN. Thanks a million!!
Google Search.....
How do I use VPN on my Orbi WiFi System with my Windows client?
How do I use VPN service on my Orbi system with my Windows client?kb.netgear.com
How do I enable the VPN service on my Orbi WiFi System using an Android or iOS device?
How do I use VPN on my Orbi system with my iOS device?kb.netgear.com
Are you using the VPN that’s built in to a router? If so, what router are you using? Looks like Asus may be the way to go!I don't have any suggestions on this issue other than to say that I'll generally test my VPN connection by using my phone (which obviously I set up to use the VPN connection). By turning off Wifi and using the cellular data connection, I ensure that my phone is not on the local network. This means it is a valid test to see if the VPN system is working without requiring me to physically leave my house. It certainly makes troubleshooting much easier!
