+1^^ to what @Teken and @Griswalduk posted above.
I really like this Voltage Drop Calculator because I can get results by wire gauge or resistance/foot, etc.
Below is the results for 1 cam (rounded off to 9 W / .75A vs. it's stated 8.6W) and just 1 has too much drop for that distance, wire size, etc.
Its gets worse as you add cams (double the drop for 2 cams, quadruple the drop for 4 cams).
I just figured that all those online voltage drop calculators aren't worth their money, even when they are free.
My installation is now completed.
In 2 locations I used 2 core 1.5 sq mm copper multi strand VCT power cable, over a length of 25 - 30 meter.
1.5 sq mm is between 15 and 16 AWG.
According to the online calculators, my voltage drop over 25 meters would be 1.2V, or 10%
My power supply delivers 12.39V, and at the end of the cables I measure 12.35 V and the other one 12.32V
Am I missing something?
