VLAN
bob2701
1,044
499
Jersey Shore
I cannot access the system from the IOS Blue Iris app on my iPhone.
I have had my system up and running for a couple of years now and decided to move all my cameras onto a VLAN. Using a Ubiquiti USG and had no problem setting up the VLAN. Local LAN is 192.168.0.XXX and VLAN is 172.16.0.XXX.
I added a second NIC into the BI server and set one to the VLAN and the other to my local LAN. I changed all the IP addresses of the cameras to the VLAN segment and made the changes in BI.
Disabled WiFi on the iPhone and can not connect. A laptop set to the VLAN works fine with the UI3 interface.
BI sees both segments but I'm not sure which one should be the main (listing of left side of config screen).
Running BI as a service on Windows 10.
