I set up my blue iris server on a vlan and set an ACL to block internet. Has worked perfectly for months and no changes.
I access the server via wireless vlan. Blue iris is set to 192.168.xx.6:## as my internal server : I also have sightound on the same vlan with a different port: YYYY
All of a sudden I lost connectivity to the servers. I can ping the host computer 192.168.xx.6 on the server without problem. But I can't ping either blue iris or signthounf
I have made absolutely no other changes. I rebooted the router and computer. Any suggestions? Very frustrating.
thank you in advance
UPDATE: I figured out that somehow windows firewall was blocking my access. Strange since I wasn't connected to the internet and don't do updates. But I disabled it and everything works fine.
PS Chat GPT was able to tell me how to diagnose the issue and eventually solved it!!
