Hi. I've been dealing with this finicky camera for a few days now. If I make no changes to the camera settings in either the camera UI or BI, it seems ok. But once I make a change to the camera's profile settings or video, trigger or record settings in Blue Iris, I get a gray screen and the 403 error. The only way to fix it is to restore the camera to factory settings and start all over again. I'd like a reliable fisheye lens camera that is NDAA-compliant and I thought this was the one. I want to make sure I try everything before sending it back.
When I add the camera, I'm simply adding the IP address, username and password and clicking "Inspect". Results appear to be normal and I'm able to choose the main and sub stream paths. Then I click "Ok" and it works just fine. Once I get into adjusting any settings beyond that... 403. Here's the inspect result:
Opening 192.168.5.107 port 80...
HTTP Get / request...
OK
ONVIF GetSystemDateAndTime
2021-07-08T22:05:31.000Z
Requesting device information...
Manufacturer: VIVOTEK
Model: FE9380-HV
FirmwareVersion: 2.2002.13.01
GetCapabilities...
Querying services
Has Search services: /onvif/search_service
Has Imaging services: /onvif/imaging_service
Has media services: /onvif/media_service
Has RTP_RTSP_TCP, requesting profiles
profile token Profile100
profile name Profile100
profile source is VideoSource1
profile source config is VideoSourceConfiguration1
profile token Profile101
profile name Profile101
profile token Profile102
profile name Profile102
profile token Profile103
profile name Profile103
requesting URI for profile Profile100
RTSP URI: /media/stream.sdp?profile=Profile100
requesting URI for profile Profile101
RTSP URI: /media/stream.sdp?profile=Profile101
requesting URI for profile Profile102
RTSP URI: /media/stream.sdp?profile=Profile102
requesting URI for profile Profile103
RTSP URI: /media/stream.sdp?profile=Profile103
Has Event services: /onvif/event_service
Has WSPullPointSupport
RelayOutputs: 0
InputConnectors: 0
Has Device IO services: /onvif/deviceio_service
AudioOutputs: 0
Done
The camera's firmware is up to date. I even went as far as rolling back the BI version to 5.4.7.11, which is stated to be the most recent stable version. No change.
In the beginning, I noticed I could keep the settings for the camera in BI and not delete it before factory resetting the camera itself. After the camera reboots, I'd get a feed. However, that no longer works.
My last thought was to do a full system restart. Alas, no change. I can't think of whatelse to do.
Version: Release 5.4.9.6 x64
OS: Windows Server 2019 Standard
CPU: Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz [9%]
RAM: 334.2M/7.91G
Vivotek FE9380-HV - Firmware 2.2002.13.01j
OK
Model: FE9380-HV
GetCapabilities...
Querying services
RelayOutputs: 0
InputConnectors: 0
AudioOutputs: 0
Done
RAM: 334.2M/7.91G
