Viewing angles on monitors
Afranze
Nov 17, 2022
93
14
Geelong
Silly question but here goes
Are there any type of monitors that still have a good picture view from sharper viewing angles?
This is our CCTV monitor and we keep It in our walk in pantry
It was originally just sitting at head height when you walk in at standing level
Now we've gotten the pantry renovated and I can only put the monitor on top of the cabinets making the view higher then before
It's out of the way up there but makes the dark unless because of the high angle . If it didn't do that the location would be ideal
There isn't really another good location to put the monitor
This is the model I got and it says the viewing angle is H170 and 160 V
Isn't that already decent?
Look into a new mount for the display. Most have the ability to tilt up/down.. some tilt more then others.
Can't find one that tilts enough for your conundrum? Make up some tapered pieces of wood for between the wall and the mount to angle to top down even more.
Reactions: TonyR
